Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
Phone lacking intelligence? Replace your logic board.
Peças
Nenhum componente especificado.
  1. Lay the phone face down with the screen in palm of hand.
    • Lay the phone face down with the screen in palm of hand.
    • Slide the grey button towards the top of the phone.
  2. While the button is slid up grab the battery on the sides and pull up with the bottom remaining in place.
    • While the button is slid up grab the battery on the sides and pull up with the bottom remaining in place.
    • Pull the battery up vertically to completely remove from phone.
  3. Kits para Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Remove four screws beneath battery using screw driver.
    • Remove four screws beneath battery using screw driver.
    • Remove three rubber screw covers with tweezers.
    • Remove the three screws under the covers with the screwdriver.
  5. Detach outer casing from back of phone.
    • Detach outer casing from back of phone.
    • NOTE: There will be a significant amount of resistance to detaching the back casing.
  6. Unsnap gold rectangular plate and silver square plate from the logic board.
    • Unsnap gold rectangular plate and silver square plate from the logic board.
  7. Remove logic board, being careful not to remove any other pieces.
    • Remove logic board, being careful not to remove any other pieces.
    • Insert new logic board with white side facing down.
    • NOTE: Make sure side buttons on logic board are correctly aligned to avoid future complications.
Conclusão
Nichole Shaw
Membro desde: 13-04-2010
1 Reputação
7 Guias de autoria
equipe
Cal Poly, Team 18-75, Johann Spring 2010 Membro de Cal Poly, Team 18-75, Johann Spring 2010
CPSU-JOHANN-S10S18G75
4 Membros
14 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,248
