Ir para o conteúdo principal
LG VX7000 Internal LCD Screen Replacement
O que você precisa
  1. LG VX7000 Internal LCD Screen Replacement, Internal LCD Screen: passo 1, imagem 1 %32
    • Using Tweezers, remove 4 rubber screw covers.
    • Remove screws located under rubber plugs using the screwdriver by turning counterclockwise.
    • NOTE: Screws will not come completely out of phone.
  2. LG VX7000 Internal LCD Screen Replacement: passo 2, imagem 1 %32
    • Using the iPod Opening Tool, pry the face plate off the front of the phone.
    • NOTE: There will be a significant amount of resistance to removing the face plate from the phone.
  3. LG VX7000 Internal LCD Screen Replacement: passo 3, imagem 1 %32
    • Unsnap gold plate from the secondary logic board.
    • Reposition the plate so that it is out of the way for face plate removal.
  4. LG VX7000 Internal LCD Screen Replacement: passo 4, imagem 1 %32
    • Twist upper half of face plate in order to release it from the hinge.
    • Using tweezers detach the speaker and the secondary battery from the faceplate, leaving wires attached.
  5. LG VX7000 Internal LCD Screen Replacement: passo 5, imagem 1 %32
    • Align new face plate in correct orientation in order to install.
Conclusão
Nichole Shaw
Membro desde: 04/13/10
1 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 18-75, Johann Spring 2010 Membro de Cal Poly, Team 18-75, Johann Spring 2010
CPSU-JOHANN-S10S18G75
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 2,219
