Ir para o conteúdo principal
LG VX7000 External LCD Display Replacement
O que você precisa
  1. LG VX7000 External LCD Display Replacement, External LCD Display: passo 1, imagem 1 %32
    • Using a pair of tweezers, remove the rubber screw covers located at each corner of the main screen.
    • NOTE: There will be a total of four rubber screw covers removed.
    • Turn the screwdriver counterclockwise to unscrew the screws located under the recently removed rubber plugs.
    • NOTE: The screws can not be completely removed from their holes.
  2. LG VX7000 External LCD Display Replacement: passo 2, imagem 1 %32
    • Using the "iPod Opening Tool", separate the faceplate from the front of the phone.
    • NOTE: There will be a significant amount of resistance when separating the faceplate from the phone.
    • Align the new faceplate in the place of the previously cracked faceplate, and press the new faceplate onto the phone.
Conclusão
Nichole Shaw
Membro desde: 04/13/10
1 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 18-75, Johann Spring 2010 Membro de Cal Poly, Team 18-75, Johann Spring 2010
CPSU-JOHANN-S10S18G75
Membros da 4
Autoria de 14 guias
Um comentário
My phone turns on but the screen is black I think because one side of the phone the is broken where you flip it open it opens but you just can't see the screen
chayp62 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,687
