Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Lay the phone, screen side down, in your palm.
Slide the grey button towards the top of the phone.
With the button unlocked, grab the battery on the sides and pull up, then slide the battery up to completely remove it from the phone.
Ferramenta utilizada nesse passo:Tweezers$4.99-
Use the Phillips #00 and remove the four screws on the lower backside of the phone.
Remove the three rubber screw covers with tweezers and then the three screws underneath using a Phillips #00 screwdriver.
Detach the outer casing from the back of the phone.
Unsnap the gold rectangular connector and silver square connector from the motherboard.
Remove the motherboard. Do not remove other components.
Insert the new motherboard with the white side facing down.
