Ir para o conteúdo principal
LG VX6100 Speaker Replacement
O que você precisa
  1. LG VX6100 Speaker Replacement, Front Case: passo 1, imagem 1 %32
    • Remove the four grey plugs using either tweezers or a push pin.
  2. LG VX6100 Speaker Replacement: passo 2, imagem 1 %32
    • Remove the four screws that are now exposed using a Phillips #00 screwdriver.
    • Be sure to put the screws in a safe place as they are very small and easy to lose.
  3. LG VX6100 Speaker Replacement: passo 3, imagem 1 %32
    • Once all the screws have been removed, use a plastic opener tool to pry the case from the rest of the phone.
    • Insert the opener tool into the seem between the case and the phone. Apply pressure to separate the two pieces.
    • Do this across the entire length of the seem until the case is no longer attached to the phone.
  4. LG VX6100 Speaker Replacement: passo 4, imagem 1 %32
    • The case can now be removed and the interior of the front is accessible.
  5. LG VX6100 Speaker Replacement, Speaker: passo 5, imagem 1 %32 LG VX6100 Speaker Replacement, Speaker: passo 5, imagem 2 %32
    • Locate the four solder joints (connected to the yellow, black, blue, and red wires) on the bottom part of the phone, connected to the speaker. It will appear as a black circular part with some holes in it.
    • Place a piece of solder wick on top of the solders.
    • Very carefully, place the tip of the soldering iron on top of the solder wick. Hold it steady until the solder is soaked up into the solder wick.
    • Soldering iron will damage circuitry if held down for too long.
    • Cut off the used solder wick with pliers and repeat this step if any solder remains.
  6. LG VX6100 Speaker Replacement: passo 6, imagem 1 %32
    • After the solder has been removed, pry out the speaker with the plastic opening tool.
Conclusão
Ryan Bishop
Membro desde: 04/17/12
1 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 12-39, Regan Spring 2012 Membro de Cal Poly, Team 12-39, Regan Spring 2012
CPSU-REGAN-S12S12G39
Membros da 3
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 511
