Ir para o conteúdo principal
LG VX6100 Keypad Replacement
O que você precisa
  1. LG VX6100 Keypad Replacement, Back Cover: passo 1, imagem 1 %32
    • Push down on the gray "PUSH" button on the back side of the phone.
    • Slide the back case downward. Then, lift and remove the case.
  2. LG VX6100 Keypad Replacement: passo 2, imagem 1 %32
    • Lift up on the battery to remove it from the case.
  3. LG VX6100 Keypad Replacement: passo 3, imagem 1 %32
    • Use a push-pin or tweezers to pry both of the tear-shaped screw covers out of the top of the phone.
  4. LG VX6100 Keypad Replacement: passo 4, imagem 1 %32
    • Use a Phillips #00 screwdriver to unscrew the six case screws from the back of the phone.
  5. LG VX6100 Keypad Replacement: passo 5, imagem 1 %32 LG VX6100 Keypad Replacement: passo 5, imagem 2 %32
    • Insert a plastic opener tool through the seam between the back case and the rest of the phone.
    • Slowly slide the tool along the seam. Lift up on the back case while you do this until the back case comes apart.
  6. LG VX6100 Keypad Replacement, Keypad: passo 6, imagem 1 %32
    • Lift the bottom of the logic board out of the case.
    • Make sure not to lift the top of the logic board, since it is still connected to the backcase of the phone.
  7. LG VX6100 Keypad Replacement: passo 7, imagem 1 %32
    • Gently lift up on any edge of the white keypad to remove it from the phone case.
Conclusão
Teal
Membro desde: 04/17/12
1 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 12-39, Regan Spring 2012 Membro de Cal Poly, Team 12-39, Regan Spring 2012
CPSU-REGAN-S12S12G39
Membros da 3
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 538
