Ir para o conteúdo principal
LG VX6000 Body Replacement
O que você precisa
  1. LG VX6000 Body Replacement, Battery: passo 1, imagem 1 %32
    • Locate the dark gray tab on the back of the phone towards the top. Push the tab towards the top of the phone to release the battery.
  2. LG VX6000 Body Replacement: passo 2, imagem 1 %32
    • Remove the battery by lifting up and rotating the battery away from the bottom edge.
  3. LG VX6000 Body Replacement, Body: passo 3, imagem 1 %32
    • Pull out the two rubber cushions located on the top of the phone using tweezers.
    • Only remove the two cushions that are circled!
  4. LG VX6000 Body Replacement: passo 4, imagem 1 %32
    • Unscrew the six screws seen on the back using a Phillips 00 Screwdriver.
    • Remove screws and carefully place on an uncluttered surface or in a small container.
  5. LG VX6000 Body Replacement: passo 5, imagem 1 %32
    • Carefully remove the back of the phone gently using your fingernails or tweezers.
    • There are a pair of red and blue wires that plugs into the motherboard. These wires will snap if you force the pieces apart.
    • To reattach the back, you must plug these wires back in.
Linha de Chegada
Barrett Wallace
Membro desde: 01/18/10
1 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 4-11, Forte Winter 2010 Membro de Cal Poly, Team 4-11, Forte Winter 2010
CPSU-FORTE-W10S4G11
Membros da 5
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 2,106
