Ir para o conteúdo principal
LG VX5500 Screen Replacement
O que você precisa
  1. LG VX5500 Screen Replacement, Battery: passo 1, imagem 1 %32 LG VX5500 Screen Replacement, Battery: passo 1, imagem 2 %32 LG VX5500 Screen Replacement, Battery: passo 1, imagem 3 %32
    • Remove the battery cover by placing your thumb on the small ridge near the top of the phone back and push downward, exposing the battery.
    • Our device did not come with a battery cover so it is not shown here.
    • Remove the battery using your finger to pry it out of the battery housing.
  2. LG VX5500 Screen Replacement, Screen: passo 2, imagem 1 %32 LG VX5500 Screen Replacement, Screen: passo 2, imagem 2 %32
    • Carefully pry off the black plastic screen cover using the iSesamo tool or another thin, flat tool.
    • The screen cover is adhered to the phone and may take some effort to pry off. If it is too difficult to remove, heat the screen with a hair dryer on low for 30 seconds to soften the adhesive.
  3. LG VX5500 Screen Replacement: passo 3, imagem 1 %32 LG VX5500 Screen Replacement: passo 3, imagem 2 %32
    • Unscrew the (4) 3.6mm screws near each corner of the phone's display panel by using a #00 Phillips head screwdriver.
    • The bottom two screws may have small rubber covers that you can remove using tweezers.
  4. LG VX5500 Screen Replacement: passo 4, imagem 1 %32 LG VX5500 Screen Replacement: passo 4, imagem 2 %32 LG VX5500 Screen Replacement: passo 4, imagem 3 %32
    • Pry off the front panel of the phone using a Plastic Opening Tool.
    • Push the tool into the crack along the side of the phone.
    • Slide the tool along the crack to detach the tabs holding the backing on the phone.
  5. LG VX5500 Screen Replacement: passo 5, imagem 1 %32 LG VX5500 Screen Replacement: passo 5, imagem 2 %32
    • Use the tweezers to lift the display adapter off the screen component.
  6. LG VX5500 Screen Replacement: passo 6, imagem 1 %32 LG VX5500 Screen Replacement: passo 6, imagem 2 %32
    • Using tweezers remove the speaker from its casing.
    • The speaker is adhered to the phone casing so it will take a small amount of force to remove it.
  7. LG VX5500 Screen Replacement: passo 7, imagem 1 %32 LG VX5500 Screen Replacement: passo 7, imagem 2 %32
    • Remove the earpiece by lifting it out of the phone casing using tweezers.
    • The earpiece is adhered to the phone casing so it will take a small amount of force to remove it.
  8. LG VX5500 Screen Replacement: passo 8, imagem 1 %32 LG VX5500 Screen Replacement: passo 8, imagem 2 %32
    • Remove the vibration motor by lifting it out of the phone casing using tweezers.
    • The motor is adhered to the phone casing so it will take a small amount of force to remove it.
  9. LG VX5500 Screen Replacement: passo 9, imagem 1 %32
    • Lift the screen components out of the phone.
Conclusão
3 outras pessoas executaram este guia.
Henry
Membro desde: 04/12/12
181 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 7-33, Maness Spring 2012 Membro de Cal Poly, Team 7-33, Maness Spring 2012
CPSU-MANESS-S12S7G33
Membros da 4
Autoria de 10 guias
2 comentários
I have it apart know need to learn to solder!
Andy Fowler - Responder
where can i purchase a replacement screen?
kalea dean - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 3,744
