Ir para o conteúdo principal
LG VX5500 Phone Casing Replacement
O que você precisa
  1. LG VX5500 Phone Casing Replacement, Battery: passo 1, imagem 1 %32 LG VX5500 Phone Casing Replacement, Battery: passo 1, imagem 2 %32 LG VX5500 Phone Casing Replacement, Battery: passo 1, imagem 3 %32
    • Remove the battery cover by placing your thumb on the small ridge near the top of the phone back and push downward, exposing the battery.
    • Our device did not come with a battery cover so it is not shown here.
    • Remove the battery using your finger to pry it out of the battery housing.
  2. LG VX5500 Phone Casing Replacement, Mother Board: passo 2, imagem 1 %32 LG VX5500 Phone Casing Replacement, Mother Board: passo 2, imagem 2 %32
    • Remove the (2) rubber screw covers located near the hinge of the phone using tweezers or a thumb tack.
    • Unscrew the (4) 3.6mm screws using a #00 Phillip's head screw driver.
  3. LG VX5500 Phone Casing Replacement: passo 3, imagem 1 %32 LG VX5500 Phone Casing Replacement: passo 3, imagem 2 %32 LG VX5500 Phone Casing Replacement: passo 3, imagem 3 %32
    • Carefully pry off the phone's backing using a plastic opening tool.
    • Slip the tool into the crack between the keypad (front panel) and the back panel.
    • Slide the tool along the sides of the phone to detach the tabs holding the backing on.
  4. LG VX5500 Phone Casing Replacement: passo 4, imagem 1 %32 LG VX5500 Phone Casing Replacement: passo 4, imagem 2 %32
    • Peel back the sticker with tweezers and hold it back with your finger.
    • Use the tweezers to lift the display adapter off the logic board.
  5. LG VX5500 Phone Casing Replacement: passo 5, imagem 1 %32 LG VX5500 Phone Casing Replacement: passo 5, imagem 2 %32
    • Lift the mother board out of the phone casing.
    • The keyboard can be easily removed once the mother board is out of the phone.
  6. LG VX5500 Phone Casing Replacement, Phone Casing: passo 6, imagem 1 %32 LG VX5500 Phone Casing Replacement, Phone Casing: passo 6, imagem 2 %32
    • Carefully pry off the black plastic screen cover using the iSesamo tool or another thin, flat tool.
    • The screen cover is adhered to the phone and may take some effort to pry off. If it is too difficult to remove, heat the screen with a hair dryer on low for 30 seconds to soften the adhesive.
  7. LG VX5500 Phone Casing Replacement: passo 7, imagem 1 %32 LG VX5500 Phone Casing Replacement: passo 7, imagem 2 %32
    • Unscrew the (4) 3.6mm screws near each corner of the phone's display panel by using a #00 Phillips head screwdriver.
    • The bottom two screws may have small rubber covers that you can remove using tweezers.
  8. LG VX5500 Phone Casing Replacement: passo 8, imagem 1 %32 LG VX5500 Phone Casing Replacement: passo 8, imagem 2 %32 LG VX5500 Phone Casing Replacement: passo 8, imagem 3 %32
    • Pry off the front panel of the phone using a Plastic Opening Tool.
    • Push the tool into the crack along the side of the phone.
    • Slide the tool along the crack to detach the tabs holding the backing on the phone.
  9. LG VX5500 Phone Casing Replacement: passo 9, imagem 1 %32 LG VX5500 Phone Casing Replacement: passo 9, imagem 2 %32
    • Use the tweezers to lift the display adapter off the screen component.
  10. LG VX5500 Phone Casing Replacement: passo 10, imagem 1 %32 LG VX5500 Phone Casing Replacement: passo 10, imagem 2 %32
    • Using tweezers remove the speaker from its casing.
    • The speaker is adhered to the phone casing so it will take a small amount of force to remove it.
  11. LG VX5500 Phone Casing Replacement: passo 11, imagem 1 %32 LG VX5500 Phone Casing Replacement: passo 11, imagem 2 %32
    • Remove the earpiece and gyroscope by lifting them out of the phone casing using tweezers.
    • The earpiece and gyroscope are adhered to the phone casing so it will take a small amount of force to remove them.
    • Be careful when removing these components as the connecting wires are easily broken/disconnected.
  12. LG VX5500 Phone Casing Replacement: passo 12, imagem 1 %32
    • Lift the screen components out of the phone.
  13. LG VX5500 Phone Casing Replacement: passo 13, imagem 1 %32
    • The phone is now fully disassembled.
    • Replace the parts indicated with your new phone casing.
Conclusão
3 outras pessoas executaram este guia.
Henry
Membro desde: 04/12/12
181 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 7-33, Maness Spring 2012 Membro de Cal Poly, Team 7-33, Maness Spring 2012
CPSU-MANESS-S12S7G33
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 565
