Ir para o conteúdo principal
LG VX5400 Logic Board Replacement
O que você precisa
  1. LG VX5400 Logic Board Replacement, Battery: passo 1, imagem 1 %32
    • Turn off the cell phone and turn it over on its back side
  2. LG VX5400 Logic Board Replacement: passo 2, imagem 1 %32
    • Hold the phone case in your palm and slide the back cover towards yourself using your thumb
  3. LG VX5400 Logic Board Replacement: passo 3, imagem 1 %32 LG VX5400 Logic Board Replacement: passo 3, imagem 2 %32 LG VX5400 Logic Board Replacement: passo 3, imagem 3 %32
    • Slide a tool or finger into the notch at the top of the battery to carefully remove it.
  4. LG VX5400 Logic Board Replacement, Outer Casing: passo 4, imagem 1 %32
    • Take the Philips screwdriver and unscrew the four visible screws on the backside of the phone indicated by the four red circles.
  5. LG VX5400 Logic Board Replacement: passo 5, imagem 1 %32
    • Then, take the pointed end of a spudger and pry out the rubber stopper to reveal the last screw at the top indicated with the blue circle.
  6. LG VX5400 Logic Board Replacement, Logic Board: passo 6, imagem 1 %32 LG VX5400 Logic Board Replacement, Logic Board: passo 6, imagem 2 %32
    • While the phone is open and faced up, carefully insert a tool into the middle to seperate the bottom half of the phone.
  7. LG VX5400 Logic Board Replacement: passo 7, imagem 1 %32 LG VX5400 Logic Board Replacement: passo 7, imagem 2 %32
    • Carefully slide out the keypad and remove the logic board. Then insert new the logic board.
Conclusão
Sourabh
Membro desde: 04/15/10
132 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 26-26, Regan Spring 2010 Membro de Cal Poly, Team 26-26, Regan Spring 2010
CPSU-REGAN-S10S26G26
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 2,512
