Ir para o conteúdo principal
LG VX5300 outer LCD screen replacement
O que você precisa
  1. LG VX5300 outer LCD screen replacement, Front LCD Screen: passo 1, imagem 1 %32
    • Remove the rubber stoppers from the four corners of the front screen.
  2. LG VX5300 outer LCD screen replacement: passo 2, imagem 1 %32
    • Using the Phillips screwdriver, carefully remove all four screws.
  3. LG VX5300 outer LCD screen replacement: passo 3, imagem 1 %32 LG VX5300 outer LCD screen replacement: passo 3, imagem 2 %32
    • To pry open the face plate, place the iFixit Opener tool in the crease of the phone.
  4. LG VX5300 outer LCD screen replacement, LCD Screen: passo 4, imagem 1 %32 LG VX5300 outer LCD screen replacement, LCD Screen: passo 4, imagem 2 %32
    • Carefully lift off the black frame around the LCD screen and set it aside.
  5. LG VX5300 outer LCD screen replacement: passo 5, imagem 1 %32
    • Lift the speaker out by using tweezers.
    • Next, lift the battery out using the tweezers.
  6. LG VX5300 outer LCD screen replacement: passo 6, imagem 1 %32
    • Using tweezers, carefully disconnect the orange ribbon from the computer chip.
  7. LG VX5300 outer LCD screen replacement: passo 7, imagem 1 %32
    • Remove the LCD screen and replace with a new one.
    • Finally, replace the battery and the speaker.
Conclusão
Ashley
Membro desde: 02/12/13
13 Reputação
Autoria de 3 guias
Equipe
Ohio State, Team 1-1, Buehl Spring 2013 Membro de Ohio State, Team 1-1, Buehl Spring 2013
OSU-BUEHL-S13S1G1
Membros da 3
Autoria de 4 guias
Um comentário
Thanks for the instructions. By chance, do you know how to replace the motherboard? Where is the mother board
Sula Tremaine - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 486
