Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Carefully slide battery cover off in a downward direction.
Using the plastic opening tool, remove the battery. Light force may be necessary.
Using a Phillips #0 screwdriver, remove the five screws from the back cover and carefully set them aside.
Using the plastic opening tool, carefully lift the back cover off.
Look to the following photo for the location of the two sensor bars.
Without disconnecting the orange wire, carefully flip the computer chip over and lay flat on the table, exposing the keypad.
Carefully remove the keypad and replace with the new keypad.
Place the back cover back on and secure it with the screws.
Insert the battery.
Slide the back cover on the phone.
