Introdução
This guide illustrates how to replace the LG VX5300 keypad.
Peças
Não são necessárias peças.
  1. Carefully slide battery cover off in a downward direction. Using the plastic opening tool, remove the battery. Light force may be necessary. Using the plastic opening tool, remove the battery. Light force may be necessary.
    • Carefully slide battery cover off in a downward direction.
    • Using the plastic opening tool, remove the battery. Light force may be necessary.
  2. Using a Phillips #0 screwdriver, remove the five screws from the back cover and carefully set them aside.
    • Using a Phillips #0 screwdriver, remove the five screws from the back cover and carefully set them aside.
  3. Using the plastic opening tool, carefully lift the back cover off.
    • Using the plastic opening tool, carefully lift the back cover off.
  4. Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  5. Before touching anything inside the phone: it is crucial that you are very cautious when working around the wiring and sensor bars. Look to the following photo for the location of the two sensor bars.
    • Before touching anything inside the phone: it is crucial that you are very cautious when working around the wiring and sensor bars.
    • Look to the following photo for the location of the two sensor bars.
    • Without disconnecting the orange wire, carefully flip the computer chip over and lay flat on the table, exposing the keypad.
  6. Carefully remove the keypad and replace with the new keypad. If sensor bars behind the volume and camera buttons fall out, gently put them back in place behind the buttons.
    • Carefully remove the keypad and replace with the new keypad.
    • If sensor bars behind the volume and camera buttons fall out, gently put them back in place behind the buttons.
  7. Carefully set the computer chip back in place.
    • Carefully set the computer chip back in place.
  8. Place the back cover back on and secure it with the screws. Place the back cover back on and secure it with the screws.
    • Place the back cover back on and secure it with the screws.
  9. Insert the battery. Slide the back cover on the phone.
    • Insert the battery.
    • Slide the back cover on the phone.
Linha de Chegada
Ashley
9 reputação
3 Guides authored
Equipe
Ohio State, Team 1-1, Buehl Spring 2013 Membro de Ohio State, Team 1-1, Buehl Spring 2013
OSU-BUEHL-S13S1G1
3 Membros
4 Guides authored
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Todo: 431
