Ir para o conteúdo principal
LG VX5200 motherboard replacement
O que você precisa
  1. LG VX5200 motherboard replacement, Battery: passo 1, imagem 1 %32 LG VX5200 motherboard replacement, Battery: passo 1, imagem 2 %32
    • Turn the phone on its back.
  2. LG VX5200 motherboard replacement: passo 2, imagem 1 %32 LG VX5200 motherboard replacement: passo 2, imagem 2 %32
    • Orient the phone as shown.
    • Remove the battery cover by pushing upward with your thumb.
  3. LG VX5200 motherboard replacement: passo 3, imagem 1 %32 LG VX5200 motherboard replacement: passo 3, imagem 2 %32
    • Place your fingernail at the top of the battery and pry the battery out towards you.
  4. LG VX5200 motherboard replacement, LG VX5200 Rear Body Panel Disassembly: passo 4, imagem 1 %32
    • Orient the phone as shown with the battery already removed.
  5. LG VX5200 motherboard replacement: passo 5, imagem 1 %32 LG VX5200 motherboard replacement: passo 5, imagem 2 %32 LG VX5200 motherboard replacement: passo 5, imagem 3 %32
    • Remove the 2 plastic plugs located on the side and upper quadrant of the rear body panel by using the push-pin and lifting outwards.
    • Use a Phillips #00 screwdriver to remove the 5 screws as shown here.
  6. LG VX5200 motherboard replacement: passo 6, imagem 1 %32 LG VX5200 motherboard replacement: passo 6, imagem 2 %32 LG VX5200 motherboard replacement: passo 6, imagem 3 %32
    • Place an iPod opener tool in the seam above the antenna.
    • Run the tool around the perimeter of the entire phone.
  7. LG VX5200 motherboard replacement: passo 7, imagem 1 %32
    • Check to see that your device looks like the attached photo.
  8. LG VX5200 motherboard replacement, main board: passo 8, imagem 1 %32 LG VX5200 motherboard replacement, main board: passo 8, imagem 2 %32 LG VX5200 motherboard replacement, main board: passo 8, imagem 3 %32
    • Locate the tabs that hold the logic board in place.
    • Pull the outer frame of the phone outwards to release the board from the tabs.
  9. LG VX5200 motherboard replacement: passo 9, imagem 1 %32 LG VX5200 motherboard replacement: passo 9, imagem 2 %32 LG VX5200 motherboard replacement: passo 9, imagem 3 %32
    • Locate the copper connection (orange-colored) on the back of the board.
    • Pry the connector free from the board with your fingernail.
  10. LG VX5200 motherboard replacement: passo 10, imagem 1 %32
    • Check to see that your device looks like the image shown.
    • Note: The image is shown with the LCD screen removed. This is not necessary for logic board removal.
Conclusão
Douglas Blaalid
Membro desde: 01/13/10
282 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 4-13, Forte Winter 2010 Membro de Cal Poly, Team 4-13, Forte Winter 2010
CPSU-FORTE-W10S4G13
Membros da 5
Autoria de 15 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 2,707
