Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Orient the phone as shown.
Remove the battery cover by pushing upward with your thumb.
Place your fingernail at the top of the battery and pry the battery out towards you.
Orient the phone as shown with the battery already removed.
Remove the 2 plastic plugs located on the side and upper quadrant of the rear body panel by using the push-pin and lifting outwards.
Use a Phillips #00 screwdriver to remove the 5 screws as shown here.
Place an iPod opener tool in the seam above the antenna.
Run the tool around the perimeter of the entire phone.
Check to see that your device looks like the attached photo.
