Ir para o conteúdo principal
LG VX5200 Camera Replacement
O que você precisa
  1. LG VX5200 Camera Replacement, Battery: passo 1, imagem 1 %32 LG VX5200 Camera Replacement, Battery: passo 1, imagem 2 %32
    • Turn the phone on its back.
  2. LG VX5200 Camera Replacement: passo 2, imagem 1 %32 LG VX5200 Camera Replacement: passo 2, imagem 2 %32
    • Orient the phone as shown.
    • Remove the battery cover by pushing upward with your thumb.
  3. LG VX5200 Camera Replacement: passo 3, imagem 1 %32 LG VX5200 Camera Replacement: passo 3, imagem 2 %32
    • Place your fingernail at the top of the battery and pry the battery out towards you.
  4. LG VX5200 Camera Replacement, Face Plate: passo 4, imagem 1 %32 LG VX5200 Camera Replacement, Face Plate: passo 4, imagem 2 %32 LG VX5200 Camera Replacement, Face Plate: passo 4, imagem 3 %32
    • Flip the phone open.
    • Remove the four rubber plugs, located at the corners of the LCD screen, with a push-pin.
    • Use a Phillips #00 screwdriver to remove the four screws located underneath the rubber plugs.
  5. LG VX5200 Camera Replacement: passo 5, imagem 1 %32 LG VX5200 Camera Replacement: passo 5, imagem 2 %32 LG VX5200 Camera Replacement: passo 5, imagem 3 %32
    • Insert the opening tool in the seam of the top portion of the flip phone.
    • Gently pry the seam open.
    • Move the opening tool around the perimeter of the seam and gently take the front LCD face plate out.
  6. LG VX5200 Camera Replacement: passo 6, imagem 1 %32 LG VX5200 Camera Replacement: passo 6, imagem 2 %32 LG VX5200 Camera Replacement: passo 6, imagem 3 %32
    • Close the flip phone.
    • Hold the base of the phone and gently remove the faceplate.
    • Place the phone and the faceplate on a clean, flat surface.
  7. LG VX5200 Camera Replacement, Camera: passo 7, imagem 1 %32 LG VX5200 Camera Replacement, Camera: passo 7, imagem 2 %32 LG VX5200 Camera Replacement, Camera: passo 7, imagem 3 %32
    • Locate the phone camera.
    • Locate the white rubber stopper to left of the camera.
    • Remove white rubber stopper by grabbing an edge with your fingers and gently pulling it off.
  8. LG VX5200 Camera Replacement: passo 8, imagem 1 %32 LG VX5200 Camera Replacement: passo 8, imagem 2 %32
    • Lift the copper ribbon cable up from the bottom right hand corner.
  9. LG VX5200 Camera Replacement: passo 9, imagem 1 %32 LG VX5200 Camera Replacement: passo 9, imagem 2 %32
    • While holding the copper connection out of the way, use your fingernail to pry the camera out of its socket.
Conclusão
Douglas Blaalid
Membro desde: 01/13/10
282 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 4-13, Forte Winter 2010 Membro de Cal Poly, Team 4-13, Forte Winter 2010
CPSU-FORTE-W10S4G13
5 Membros
Autoria de 15 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Ao todo: 2,330
