Introdução
This guide shows how to remove the battery of the LG VX5200 cell phone.
Turn off the cellphone. Remove the cover of the cellphone by applying downward pressure to raised area and pushing away from antenna. Remove the battery by lifting up with your finger in the space at the top of the device.
  • Turn off the cellphone.
  • Remove the cover of the cellphone by applying downward pressure to raised area and pushing away from antenna.
  • Remove the battery by lifting up with your finger in the space at the top of the device.
Adicionar comentário
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Place the battery to the side  away from liquids or heat.
  • Place the battery to the side away from liquids or heat.
Conclusão
3 outras pessoas concluíram este guia.
jmarcum
16 reputação
4 Guides authored
Equipe
Cal Poly, Team 9-18, Regan Fall 2009 Membro de Cal Poly, Team 9-18, Regan Fall 2009
CPSU-REGAN-F09S9G18
5 Membros
4 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Todo: 3,641
