Ir para o conteúdo principal
LG VX4500 Motherboard Replacement
O que você precisa
  1. LG VX4500 Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Turn the closed phone so that the back panel is facing you.
    • Press down and forward firmly on the gray tab in the middle of the phone.
  2. LG VX4500 Motherboard Replacement: passo 2, imagem 1 %32 LG VX4500 Motherboard Replacement: passo 2, imagem 2 %32
    • Now just lift up on the battery and remove it from the phone.
  3. LG VX4500 Motherboard Replacement, Rear Cover: passo 3, imagem 1 %32
    • Remove the rubber grommet using a Spudger.
  4. LG VX4500 Motherboard Replacement: passo 4, imagem 1 %32
    • Be sure not to lose the screws. They are small!
    • Remove the five screws using a Phillips #00 Screwdriver.
  5. LG VX4500 Motherboard Replacement: passo 5, imagem 1 %32 LG VX4500 Motherboard Replacement: passo 5, imagem 2 %32 LG VX4500 Motherboard Replacement: passo 5, imagem 3 %32
    • When removing back cover, be careful not to break the speaker wires.
    • Using an Opening Tool, carefully pry off the back cover.
    • Using tweezers, gently pull the speaker wires out.
  6. LG VX4500 Motherboard Replacement: passo 6, imagem 1 %32
    • Separate the two halves.
  7. LG VX4500 Motherboard Replacement, Keypad: passo 7, imagem 1 %32 LG VX4500 Motherboard Replacement, Keypad: passo 7, imagem 2 %32 LG VX4500 Motherboard Replacement, Keypad: passo 7, imagem 3 %32
    • Carefully pry and lift up on the logic board using an iPod Opening Tool.
  8. LG VX4500 Motherboard Replacement: passo 8, imagem 1 %32
    • Carefully flip the logic board up and out of the way.
  9. LG VX4500 Motherboard Replacement: passo 9, imagem 1 %32 LG VX4500 Motherboard Replacement: passo 9, imagem 2 %32 LG VX4500 Motherboard Replacement: passo 9, imagem 3 %32
    • Use an iPod Opening Tool to lift up on the keypad and pull it out.
  10. LG VX4500 Motherboard Replacement, Motherboard: passo 10, imagem 1 %32
    • DO NOT TOUCH SOLDERING IRON. IT IS EXTREMELY HOT.
    • Use a soldering iron to desolder the solder joint on the front of the motherboard.
    • If you need more information on soldering, refer to this guide.
  11. LG VX4500 Motherboard Replacement: passo 11, imagem 1 %32
    • Desolder the joint on the back using a soldering iron.
  12. LG VX4500 Motherboard Replacement: passo 12, imagem 1 %32 LG VX4500 Motherboard Replacement: passo 12, imagem 2 %32 LG VX4500 Motherboard Replacement: passo 12, imagem 3 %32
    • Carefully detach the ribbon cable and remove the motherboard.
Conclusão
David Foster
Membro desde: 04/11/10
1 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 25-88, Amido Spring 2010 Membro de Cal Poly, Team 25-88, Amido Spring 2010
CPSU-AMIDO-S10S25G88
Membros da 4
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 1,559
