Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the four rubber stoppers around the main screen using the pointed end of the spudger.
Use the Phillips #00 screwdriver to remove the four screws that were under the rubber stoppers.
Use a plastic opening tool to pry the top end of the phone open.
Use a second plastic opening tool to slide down the gap and pry open the case while prying the top panel with the first plastic opening tool.
Use the same method on the opposite side of the phone.
Remove plastic screen panel to reveal the internal components.
Remove the screen board by lifting it away from the phone.
Remove the speaker by prying with the spudger.
