Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
This guide will show you how to replace the screen of an LG VX4400 cell phone. This repair guide is useful if the screen of the phone is damaged or broken. This moderately difficult fix needs no special skills to complete, but be sure to have all the needed materials on hand.
  1. Remove the four rubber stoppers around the main screen using the pointed end of the spudger. Remove the four rubber stoppers around the main screen using the pointed end of the spudger.
    • Remove the four rubber stoppers around the main screen using the pointed end of the spudger.
  2. Use the Phillips #00 screwdriver to remove the four screws that were under the rubber stoppers.
    • Use the Phillips #00 screwdriver to remove the four screws that were under the rubber stoppers.
  3. Kits para Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Use a plastic opening tool to pry the top end of the phone open. Use a second plastic opening tool to slide down the gap and pry open the case while prying the top panel with the first plastic opening tool. Use the same method on the opposite side of the phone.
    • Use a plastic opening tool to pry the top end of the phone open.
    • Use a second plastic opening tool to slide down the gap and pry open the case while prying the top panel with the first plastic opening tool.
    • Use the same method on the opposite side of the phone.
  5. Remove plastic screen panel to reveal the internal components. Remove plastic screen panel to reveal the internal components.
    • Remove plastic screen panel to reveal the internal components.
  6. Remove the screen board by lifting it away from the phone. Remove the speaker by prying with the spudger. Remove the speaker by prying with the spudger.
    • Remove the screen board by lifting it away from the phone.
    • Remove the speaker by prying with the spudger.
  7. Press out the plastic screen gently. Press out the plastic screen gently. Press out the plastic screen gently.
    • Press out the plastic screen gently.
Conclusão
Nico Chiarito
Membro desde: 21-01-2010
22 Reputação
5 Guias de autoria
equipe
Cal Poly, Team 8-47, Regan Winter 2010 Membro de Cal Poly, Team 8-47, Regan Winter 2010
CPSU-REGAN-W10S8G47
5 Membros
8 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 2,363
