Ir para o conteúdo principal
LG V50 ThinQ Fingerprint Sensor Replacement
O que você precisa
  1. LG V50 ThinQ Fingerprint Sensor Replacement, Fingerprint Sensor: passo 1, imagem 1 %32 LG V50 ThinQ Fingerprint Sensor Replacement, Fingerprint Sensor: passo 1, imagem 2 %32 LG V50 ThinQ Fingerprint Sensor Replacement, Fingerprint Sensor: passo 1, imagem 3 %32
    • Flip the phone over, so that the back of the phone is facing you.
    • With the opening pick, pry open the back cover of the phone by moving the opening pick along all sides to reveal the internal components.
  2. LG V50 ThinQ Fingerprint Sensor Replacement: passo 2, imagem 1 %32 LG V50 ThinQ Fingerprint Sensor Replacement: passo 2, imagem 2 %32 LG V50 ThinQ Fingerprint Sensor Replacement: passo 2, imagem 3 %32
    • Locate the fingerprint sensor on the back cover of the phone.
    • Use a pry tool to pry the fingerprint sensor from the back cover.
    • Place the new sensor in the same orientation as the old one and install the new sensor following the instruction in reverse order.
Conclusão
Bryan B
Membro desde: 11/02/23
86 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 2-3, Gulbrandsen Fall 2023 Membro de UMass Dartmouth, Team 2-3, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G3
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 23
Duração total: 86
