Ir para o conteúdo principal
LG V30 Plus Rear Glass Replacement
O que você precisa
  1. LG V30 Plus Rear Glass Replacement, Rear Glass: passo 1, imagem 1 %32
    • Use a pair of iOpeners by heating them in a microwave and placing the hot pads on the edges of the phone.
    • Allow to sit for 1-2 minutes to heat up the adhesive.
    • A heat gun may need to be used if you have trouble separating the backing in the next step.
    Pergunte ao FixBot
    Comentar
  2. LG V30 Plus Rear Glass Replacement: passo 2, imagem 1 %32 LG V30 Plus Rear Glass Replacement: passo 2, imagem 2 %32
    • Insert an Opening Tool into the seam between the rear glass and side of the phone.
    • Pry the glass off just enough to insert an Opening Pick.
    • Slide the Opening Tool around the edges of the device, placing Opening Picks regularly.
    Pergunte ao FixBot
    Comentar
  3. LG V30 Plus Rear Glass Replacement: passo 3, imagem 1 %32
    • Once all edges of the device are lifted free, use a Suction Handle to gently pull the rear glass off the device.
    Pergunte ao FixBot
    Comentar
Conclusão
Geoffrey Smith
Membro desde: 04/18/19
416 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S1-G3, Maness Spring 2019 Membro de Cal Poly, Team S1-G3, Maness Spring 2019
CPSU-MANESS-S19S1G3
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 19
Últimos 30 dias: 60
Ao todo: 1,493
