Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
If your device isn’t turning on even after a charge, the battery may be faulty. Before you remove the battery, be advised that there may be a strong adhesive holding the battery with the phone. Use this guide to replace the battery in your device.
O que você precisa
Use a pair of iOpeners by heating them in a microwave and placing the hot pads on the edges of the phone.
Allow to sit for 1-2 minutes to heat up the adhesive.
Gently push down on the small black tab with a Spudger to release the protective board.
Slide an Opening Tool between the phone and the protective board and slide along the edges of the phone to unclip it.
Carefully wiggle the board back and forth while gently pulling to unclip the last attachment point.
Use a Spudger to get between the battery and the phone and pry each edge of the battery away from the board.
Insert Opening Picks if needed to keep the battery elevated.
Uma outra pessoa concluiu este guia.
Um comentário
I did this and now my phone’s touch screen is unresponsive. The power button and volume buttons work and the phone turns on, but I cannot unlock my phone due to the touch screen not responding
