Ir para o conteúdo principal
LG V30 Rear Camera Replacement
O que você precisa
Vídeo de Apresentação
  1. LG V30 Rear Camera Replacement, Rear Camera: passo 1, imagem 1 %32 LG V30 Rear Camera Replacement, Rear Camera: passo 1, imagem 2 %32 LG V30 Rear Camera Replacement, Rear Camera: passo 1, imagem 3 %32
    • Insert a SIM card eject tool into the small hole on the right side of the phone to release the SIM card tray from the phone.
    • Pull the SIM card tray out from the phone.
  2. LG V30 Rear Camera Replacement: passo 2, imagem 1 %32 LG V30 Rear Camera Replacement: passo 2, imagem 2 %32
    • Use a heat gun to apply heat to the back cover.
  3. LG V30 Rear Camera Replacement: passo 3, imagem 1 %32 LG V30 Rear Camera Replacement: passo 3, imagem 2 %32 LG V30 Rear Camera Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Plastic Cards
    $2.99
    Comprar
    • Use a suction cup to lift up the back cover up.
    • Insert the edge of a plastic card into the space created between the cover and frame.
  4. LG V30 Rear Camera Replacement: passo 4, imagem 1 %32 LG V30 Rear Camera Replacement: passo 4, imagem 2 %32 LG V30 Rear Camera Replacement: passo 4, imagem 3 %32
    • Insert a second card where you have created an opening with the first card and slide it along the bottom edge of the phone.
  5. LG V30 Rear Camera Replacement: passo 5, imagem 1 %32 LG V30 Rear Camera Replacement: passo 5, imagem 2 %32 LG V30 Rear Camera Replacement: passo 5, imagem 3 %32
    • Continue to slide the cards around the remaining three edges to release the adhesive.
  6. LG V30 Rear Camera Replacement: passo 6, imagem 1 %32 LG V30 Rear Camera Replacement: passo 6, imagem 2 %32 LG V30 Rear Camera Replacement: passo 6, imagem 3 %32
    • Remove the back cover.
  7. LG V30 Rear Camera Replacement: passo 7, imagem 1 %32
    • Remove the ten Phillips #000 screws from the midframe.
  8. LG V30 Rear Camera Replacement: passo 8, imagem 1 %32 LG V30 Rear Camera Replacement: passo 8, imagem 2 %32 LG V30 Rear Camera Replacement: passo 8, imagem 3 %32
    • Using a plastic spudger, pry up the midframe of the phone.
  9. LG V30 Rear Camera Replacement: passo 9, imagem 1 %32 LG V30 Rear Camera Replacement: passo 9, imagem 2 %32
    • Remove the midframe.
  10. LG V30 Rear Camera Replacement: passo 10, imagem 1 %32 LG V30 Rear Camera Replacement: passo 10, imagem 2 %32 LG V30 Rear Camera Replacement: passo 10, imagem 3 %32
    • Use the plastic spudger to pry up the four press fit connectors on the top portion of the motherboard.
  11. LG V30 Rear Camera Replacement: passo 11, imagem 1 %32 LG V30 Rear Camera Replacement: passo 11, imagem 2 %32 LG V30 Rear Camera Replacement: passo 11, imagem 3 %32
    • Pry up the speaker panel with a plastic spudger and remove it from the phone.
  12. LG V30 Rear Camera Replacement: passo 12, imagem 1 %32 LG V30 Rear Camera Replacement: passo 12, imagem 2 %32 LG V30 Rear Camera Replacement: passo 12, imagem 3 %32
    • Use a spudger to pry up the two press fit connectors on the bottom portion of the midframe.
  13. LG V30 Rear Camera Replacement: passo 13, imagem 1 %32 LG V30 Rear Camera Replacement: passo 13, imagem 2 %32 LG V30 Rear Camera Replacement: passo 13, imagem 3 %32
    • Use a spudger to pry up the motherboard and lift it out of the phone's frame.
  14. LG V30 Rear Camera Replacement: passo 14, imagem 1 %32 LG V30 Rear Camera Replacement: passo 14, imagem 2 %32 LG V30 Rear Camera Replacement: passo 14, imagem 3 %32
    • Flip over the motherboard.
    • Using a plastic spudger, pry up the press fit connector for the first camera.
  15. LG V30 Rear Camera Replacement: passo 15, imagem 1 %32 LG V30 Rear Camera Replacement: passo 15, imagem 2 %32
    Comprar
    • Remove the camera with a pair of ESD safe tweezers.
  16. LG V30 Rear Camera Replacement: passo 16, imagem 1 %32 LG V30 Rear Camera Replacement: passo 16, imagem 2 %32 LG V30 Rear Camera Replacement: passo 16, imagem 3 %32
    • Pry up the second camera with a spudger.
    • The press fit connector has already been disconnected, but the camera module is still lightly adhered to the motherboard.
    • Remove the second camera with a pair of tweezers.
Conclusão
Witrigs
Membro desde: 11/24/15
69.493 Reputação
Autoria de 378 guias
Um comentário
Does this make it no longer waterproof?
Rob Hoover - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 24
Duração total: 2,448
