Ir para o conteúdo principal
LG V10 Battery Replacement
O que você precisa
  1. LG V10 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Wedge the flat end of the plastic spudger, or the tip of your finger, in between the back cover and the LG V10’s charging port.
    • If using a spudger, it should not be in the charging port, but between the metal lining of the charging port and the back cover.
    • Carefully lift up on the spudger or with your finger so that the back cover pops up. The rest of the back cover should easily come off by sliding a finger or spudger under the back cover and around the sides.
  2. LG V10 Battery Replacement: passo 2, imagem 1 %32 LG V10 Battery Replacement: passo 2, imagem 2 %32
    • There’s an impression next to the battery for the user to use their finger to pry the battery out; pry the battery out using your finger or the flat end of the spudger.
Conclusão
After replacing the old battery with a new one, reattach the back cover and press down on all sides to make sure it's properly reattached.
3 outras pessoas executaram este guia.
Nikolai Lesh
Membro desde: 03/13/14
344 Reputação
Autoria de 1 guia
Equipe
Master Techs Membro de Master Techs
Community
Membros da 319
Autoria de 1.352 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 2,898
