Introdução
This guide will teach you how to remove the SD card on your LG Ultimate 2. In order to remove the SD card, you will need to use a spudger in order to loosen the back of the phone. Then, you will remove the back of the phone with your hands. Finally, you will use your hand or a metal spudger to pull the SD card out of the phone.
O que você precisa
Wedge the plastic opening tool into the seam between the plastic backing and the rest of the phone.
Uma outra pessoa concluiu este guia.
