Ir para o conteúdo principal
LG Ultimate 2 Digitizer Replacement
O que você precisa
  1. LG Ultimate 2 Digitizer Replacement, Battery: passo 1, imagem 1 %32
    • Wedge the plastic opening tool into the seam between the plastic backing and the rest of the phone.
  2. LG Ultimate 2 Digitizer Replacement: passo 2, imagem 1 %32
    • Use your hand to pull the plastic cover completely off of the phone.
  3. LG Ultimate 2 Digitizer Replacement: passo 3, imagem 1 %32
    • Insert the plastic opening tool into the wedge near the bottom of the battery.
    • Lift the battery out.
  4. LG Ultimate 2 Digitizer Replacement, Digitizer: passo 4, imagem 1 %32 LG Ultimate 2 Digitizer Replacement, Digitizer: passo 4, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the 11 mid-frame screws.
  5. LG Ultimate 2 Digitizer Replacement: passo 5, imagem 1 %32 LG Ultimate 2 Digitizer Replacement: passo 5, imagem 2 %32
    • Insert the plastic opening tool to start wedging the phone apart.
    • Trace the plastic opening tool along the edge for the entire perimeter of the phone, pulling it apart as you go.
  6. LG Ultimate 2 Digitizer Replacement: passo 6, imagem 1 %32
    • Use a plastic opening tool or fingernail to separate the zip connector.
    • The zip connector does not detach completely from the phone, but acts as a flap.
  7. LG Ultimate 2 Digitizer Replacement: passo 7, imagem 1 %32
    • Insert the plastic opening tool between the screen and the base. This may be difficult because of the adhesive, but enough leverage should force an opening.
  8. LG Ultimate 2 Digitizer Replacement: passo 8, imagem 1 %32
    • Continue moving the plastic opening tool along the edge of the screen, separating the pieces from the adhesive.
    • A hair dryer might be useful to help melt the adhesive.
  9. LG Ultimate 2 Digitizer Replacement: passo 9, imagem 1 %32
    • Pry the screen off after all pieces have been loosened from the adhesive.
Conclusão
Devin Isenhower
Membro desde: 03/21/18
329 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S5-G2, Baechle Spring 2018 Membro de IUPUI, Team S5-G2, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G2
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 9
Duração total: 384
