Ir para o conteúdo principal
  1. Use the plastic opening tool to pry off the back cover. Use the plastic opening tool to pry off the back cover.
    • Use the plastic opening tool to pry off the back cover.
  2. Lift the battery out of place.
    • Lift the battery out of place.
    • When replacing the battery, the (+) and (-) symbols must match up with the phone's charging nodes.
  3. Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000). Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000).
    • Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000).
  4. Use a plastic opening tool to loosen the tabs around the edge of the phone. Inserting a thin piece of plastic will help prevent opened tabs from locking back into place.
    • Use a plastic opening tool to loosen the tabs around the edge of the phone.
    • Inserting a thin piece of plastic will help prevent opened tabs from locking back into place.
    • This step can be frustrating, but requires patience. Avoid the temptation to pry the panel loose. Using excessive force may break the delicate tabs.
  5. Use a plastic opening tool to disconnect the touchscreen from the motherboard.
    • Use a plastic opening tool to disconnect the touchscreen from the motherboard.
    • The motherboard will be completely free from the front panel after this step.
Conclusão
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 35
