Introdução
This guide will assist in successfully replacing the LG Tribute touchscreen.
O que você precisa
Use a plastic opening tool to disconnect the touchscreen from the motherboard.
Use a thin piece of plastic to carefully peel the frame away from the touchscreen glass.
When the frame is completely free, remove all of the glue.
12 outras pessoas executaram este guia.
4 comentários
thank you for all ypu work at web site
Can you peel away lens without taking apart ?
Must I remove the motherboard to replace the front cover with the glass?
I messed up the speaker is there a way to replace or fix it
