Ir para o conteúdo principal
LG Tribute Touchscreen Replacement
O que você precisa
  1. LG Tribute Touchscreen Replacement, Battery: passo 1, imagem 1 %32 LG Tribute Touchscreen Replacement, Battery: passo 1, imagem 2 %32
    • Use the plastic opening tool to pry off the back cover.
  2. LG Tribute Touchscreen Replacement: passo 2, imagem 1 %32
    • Lift the battery out of place.
    • When replacing the battery, the (+) and (-) symbols must match up with the phone's charging nodes.
  3. LG Tribute Touchscreen Replacement, Mid-panel: passo 3, imagem 1 %32 LG Tribute Touchscreen Replacement, Mid-panel: passo 3, imagem 2 %32
    • Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000).
  4. LG Tribute Touchscreen Replacement: passo 4, imagem 1 %32 LG Tribute Touchscreen Replacement: passo 4, imagem 2 %32
    • Use a plastic opening tool to loosen the tabs around the edge of the phone.
    • Inserting a thin piece of plastic will help prevent opened tabs from locking back into place.
    • This step can be frustrating, but requires patience. Avoid the temptation to pry the panel loose. Using excessive force may break the delicate tabs.
  5. LG Tribute Touchscreen Replacement, Motherboard: passo 5, imagem 1 %32
    • Use a plastic opening tool to disconnect the touchscreen from the motherboard.
    • The motherboard will be completely free from the front panel after this step.
  6. LG Tribute Touchscreen Replacement, Touchscreen: passo 6, imagem 1 %32 LG Tribute Touchscreen Replacement, Touchscreen: passo 6, imagem 2 %32 LG Tribute Touchscreen Replacement, Touchscreen: passo 6, imagem 3 %32
    • Use a thin piece of plastic to carefully peel the frame away from the touchscreen glass.
    • When the frame is completely free, remove all of the glue.
    • When removing the glue, be sure the speaker grill and LED light spacer do not dislodge.
Conclusão
12 outras pessoas executaram este guia.
4 comentários
thank you for all ypu work at web site
salah dholman - Responder
Can you peel away lens without taking apart ?
mikeknapik1 - Responder
Must I remove the motherboard to replace the front cover with the glass?
Deb Schell - Responder
I messed up the speaker is there a way to replace or fix it
bigestbabybratt - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 12
Duração total: 16,166
