Pular para o conteúdo principal
Introdução
The rear facing camera on the LG Tribute is a fairly simple component to replace. The phone takes only a couple minutes to break down, and the camera can be replaced without any soldering.
  1. Use the plastic opening tool to pry off the back cover. Use the plastic opening tool to pry off the back cover.
    • Use the plastic opening tool to pry off the back cover.
  2. Lift the battery out of place.
    • Lift the battery out of place.
    • When replacing the battery, the (+) and (-) symbols must match up with the phone's charging nodes.
  3. kits de reparo de baterias de iPhone
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  4. Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000). Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000).
    • Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000).
  5. Use a plastic opening tool to loosen the tabs around the edge of the phone. Inserting a thin piece of plastic will help prevent opened tabs from locking back into place.
    • Use a plastic opening tool to loosen the tabs around the edge of the phone.
    • Inserting a thin piece of plastic will help prevent opened tabs from locking back into place.
    • This step can be frustrating, but requires patience. Avoid the temptation to pry the panel loose. Using excessive force may break the delicate tabs.
  6. Disconnect the rear facing camera from the motherboard using a plastic opening tool. Lift the rear facing camera out of its housing.
    • Disconnect the rear facing camera from the motherboard using a plastic opening tool.
    • Lift the rear facing camera out of its housing.
Conclusão
2 outras pessoas concluíram este guia.
Gustav Wolter
Membro desde: 25-01-2016
196 reputação
Autoria de 1 guia
Equipe
UWS, Team 1-1, Schneider-Bateman Spring 2016 Membro de UWS, Team 1-1, Schneider-Bateman Spring 2016
UWS-SCHNEIDER-BATEMAN-S16S1G1
3 Membros
8 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 6
Todo: 476
