Ir para o conteúdo principal
LG Tribute Motherboard Replacement
O que você precisa
  1. LG Tribute Motherboard Replacement, Battery: passo 1, imagem 1 %32 LG Tribute Motherboard Replacement, Battery: passo 1, imagem 2 %32
    • Use the plastic opening tool to pry off the back cover.
  2. LG Tribute Motherboard Replacement: passo 2, imagem 1 %32
    • Lift the battery out of place.
    • When replacing the battery, the (+) and (-) symbols must match up with the phone's charging nodes.
  3. LG Tribute Motherboard Replacement, Mid-panel: passo 3, imagem 1 %32 LG Tribute Motherboard Replacement, Mid-panel: passo 3, imagem 2 %32
    • Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000).
  4. LG Tribute Motherboard Replacement: passo 4, imagem 1 %32 LG Tribute Motherboard Replacement: passo 4, imagem 2 %32
    • Use a plastic opening tool to loosen the tabs around the edge of the phone.
    • Inserting a thin piece of plastic will help prevent opened tabs from locking back into place.
    • This step can be frustrating, but requires patience. Avoid the temptation to pry the panel loose. Using excessive force may break the delicate tabs.
  5. LG Tribute Motherboard Replacement, Motherboard: passo 5, imagem 1 %32
    • Use a plastic opening tool to disconnect the touchscreen from the motherboard.
    • The motherboard will be completely free from the front panel after this step.
  6. LG Tribute Motherboard Replacement, Motherboard: passo 6, imagem 1 %32 LG Tribute Motherboard Replacement, Motherboard: passo 6, imagem 2 %32 LG Tribute Motherboard Replacement, Motherboard: passo 6, imagem 3 %32
    • Remove SIM card by sliding it out of its housing.
    • Remove the front-facing camera using a plastic opening tool.
    • Remove rear-facing camera using a plastic opening tool.
    • Connect these three components to the new motherboard.
Conclusão
3 outras pessoas executaram este guia.
2 comentários
ممكن تشريح بوردة lg ls660
nabeel - Responder
For those that find this guide and are looking to dissasemble an lg tribute 2, Make sure to remove your sim card before romoving the cover that has screws. other than that its the same, but i spent a half hour removing my cover carefully just to find out the sd card had held the cover and motherboard togeather, causing Added risk of damage.
Christian Rolfe - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 3,853
