Ir para o conteúdo principal
LG Tribute HD Motherboard Replacement
O que você precisa
  1. LG Tribute HD Motherboard Replacement, Battery and SD Card: passo 1, imagem 1 %32 LG Tribute HD Motherboard Replacement, Battery and SD Card: passo 1, imagem 2 %32
    • Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove.
  2. LG Tribute HD Motherboard Replacement: passo 2, imagem 1 %32 LG Tribute HD Motherboard Replacement: passo 2, imagem 2 %32
    • Pull the battery out of the phone.
    • Remove the SD Card by sliding the card out as shown.
  3. LG Tribute HD Motherboard Replacement, Motherboard: passo 3, imagem 1 %32 LG Tribute HD Motherboard Replacement, Motherboard: passo 3, imagem 2 %32
    • Remove the twelve 2mm JIS #00 screws from the mid-frame.
  4. LG Tribute HD Motherboard Replacement: passo 4, imagem 1 %32 LG Tribute HD Motherboard Replacement: passo 4, imagem 2 %32 LG Tribute HD Motherboard Replacement: passo 4, imagem 3 %32
    • Using a plastic opening tool, remove the antenna extender from the mid-frame.
  5. LG Tribute HD Motherboard Replacement: passo 5, imagem 1 %32 LG Tribute HD Motherboard Replacement: passo 5, imagem 2 %32
    • Using your fingers, remove the mid-frame.
  6. LG Tribute HD Motherboard Replacement: passo 6, imagem 1 %32 LG Tribute HD Motherboard Replacement: passo 6, imagem 2 %32 LG Tribute HD Motherboard Replacement: passo 6, imagem 3 %32
    • Use a plastic opening tool to disconnect the front and rear cameras from the motherboard and pull out to remove.
  7. LG Tribute HD Motherboard Replacement: passo 7, imagem 1 %32 LG Tribute HD Motherboard Replacement: passo 7, imagem 2 %32 LG Tribute HD Motherboard Replacement: passo 7, imagem 3 %32
    • Using a plastic opening tool, pry up the front facing speaker and remove from the phone.
  8. LG Tribute HD Motherboard Replacement: passo 8, imagem 1 %32
    • Disconnect the display from the motherboard.
  9. LG Tribute HD Motherboard Replacement: passo 9, imagem 1 %32 LG Tribute HD Motherboard Replacement: passo 9, imagem 2 %32
    • Use a plastic opening tool to pry up the motherboard and pull out to remove.
Conclusão
Aalia Mohammed
Membro desde: 02/14/18
448 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S1-G3, Nance Spring 2018 Membro de USF Tampa, Team S1-G3, Nance Spring 2018
USFT-NANCE-S18S1G3
Membros da 4
Autoria de 20 guias
Um comentário
svp ou peut-on trouver cette carte mère
Mourasilva Silva - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 965
