Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove.
Pull the battery out of the phone.
Remove the SD Card by sliding the card out as shown.
Remove the twelve 2mm JIS #00 screws from the mid-frame.
Using a plastic opening tool, remove the antenna extender from the mid-frame.
Use plastic opening tool to pry up the flex cable from the back panel.
Flip over and push on the back side of the headphone jack to dislodge it.
