Ir para o conteúdo principal
LG Tribute 5 Speaker Replacement
O que você precisa
  1. LG Tribute 5 Speaker Replacement, Battery: passo 1, imagem 1 %32 LG Tribute 5 Speaker Replacement, Battery: passo 1, imagem 2 %32
    • Using an iFixit opening tool, gently pull outward on the cutout on the bottom left corner of the phone to remove the back cover.
  2. LG Tribute 5 Speaker Replacement: passo 2, imagem 1 %32 LG Tribute 5 Speaker Replacement: passo 2, imagem 2 %32 LG Tribute 5 Speaker Replacement: passo 2, imagem 3 %32
    • Gently lift the battery out from the compartment.
    • Use an iFixit opening tool to slide out the SD card and nano sim card from the device as shown.
  3. LG Tribute 5 Speaker Replacement, Front Speaker: passo 3, imagem 1 %32 LG Tribute 5 Speaker Replacement, Front Speaker: passo 3, imagem 2 %32 LG Tribute 5 Speaker Replacement, Front Speaker: passo 3, imagem 3 %32
    • Remove the nine 2mm JIS #00 screws from the mid-frame.
  4. LG Tribute 5 Speaker Replacement: passo 4, imagem 1 %32 LG Tribute 5 Speaker Replacement: passo 4, imagem 2 %32 LG Tribute 5 Speaker Replacement: passo 4, imagem 3 %32
    • Using an iFixit opening tool, remove the antenna extender located at the bottom.
  5. LG Tribute 5 Speaker Replacement: passo 5, imagem 1 %32 LG Tribute 5 Speaker Replacement: passo 5, imagem 2 %32
    • Gently remove the mid-frame using an iFixit opening tool.
    • Avoid applying too much force when separating the mid frame. Too much force can bend or damage the device.
  6. LG Tribute 5 Speaker Replacement: passo 6, imagem 1 %32
    • Using an iFixit opening tool, gently pull up the front speaker from its compartment located on the top of the motherboard.
Conclusão
Equipe
UW Tacoma, Team S1-G6, Cardinal Spring 2019 Membro de UW Tacoma, Team S1-G6, Cardinal Spring 2019
UWT-CARDINAL-S19S1G6
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 151
