Ir para o conteúdo principal
Fix Your Stuff
Right to Repair
Parts & Tools
Introdução
This guide will explain how to replace the rear camera on the LG Treasure.
Peças
Nenhum componente especificado.
  1. Make sure the LG Treasure is turned off. Pull off the back cover from the phone using the groove on the bottom right side.
    • Make sure the LG Treasure is turned off.
    • Pull off the back cover from the phone using the groove on the bottom right side.
  2. Remove the battery from the phone by lifting up on the bottom end of the battery.
    • Remove the battery from the phone by lifting up on the bottom end of the battery.
  3. Remove all 9 of the 3 mm Phillips #000 screws from the digitizer. Work your way around the edge of the phone, gently prying the digitizer off the phone.
    • Remove all 9 of the 3 mm Phillips #000 screws from the digitizer.
    • Work your way around the edge of the phone, gently prying the digitizer off the phone.
  4. Pull up on the gold film-like connector which is to the left side of camera. Once you have pulled the connector loose you can then gently lift the rear camera out of the phone. Pull up on the gold film-like connector which is to the left side of camera. Once you have pulled the connector loose you can then gently lift the rear camera out of the phone.
    • Pull up on the gold film-like connector which is to the left side of camera. Once you have pulled the connector loose you can then gently lift the rear camera out of the phone.
Conclusão
2 outras pessoas concluíram este guia.
david amirahmadi
Membro desde: 15-02-2018
546 Reputation
5 Guias de autoria
Equipe
UW Stout, Team S8-G5, Ogden Spring 2018 Membro de UW Stout, Team S8-G5, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G5
3 Membros
5 Guias de autoria
Adicione um comentário
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 115
