O que você precisa
There are 2 hidden screws that need to be removed.
Remove the rubber covering that covers the hidden screws.
Remove both of the hidden screws using a Philips #00 screwdriver.
7 outras pessoas executaram este guia.
3 comentários
where do you get the parts
where to you get the replacement part
Cannibalize another headphone set typically one that is wired and steal the wires from it to replace the worn ones assuming the original speakers aren't blown
