Ir para o conteúdo principal
LG Tone Pro HBS-770 Speaker Replacement
O que você precisa
  1. LG Tone Pro HBS-770 Speaker Replacement, Locate Hidden Screw: passo 1, imagem 1 %32 LG Tone Pro HBS-770 Speaker Replacement, Locate Hidden Screw: passo 1, imagem 2 %32 LG Tone Pro HBS-770 Speaker Replacement, Locate Hidden Screw: passo 1, imagem 3 %32
    • There are 2 hidden screws that need to be removed.
    • Remove the rubber covering that covers the hidden screws.
  2. LG Tone Pro HBS-770 Speaker Replacement, Remove Hidden Screws: passo 2, imagem 1 %32 LG Tone Pro HBS-770 Speaker Replacement, Remove Hidden Screws: passo 2, imagem 2 %32
    • Remove both of the hidden screws using a Philips #00 screwdriver.
  3. LG Tone Pro HBS-770 Speaker Replacement, Pry Open Housing: passo 3, imagem 1 %32 LG Tone Pro HBS-770 Speaker Replacement, Pry Open Housing: passo 3, imagem 2 %32 LG Tone Pro HBS-770 Speaker Replacement, Pry Open Housing: passo 3, imagem 3 %32
    • Use a guitar pick or any pry opening tool to open the housing.
  4. LG Tone Pro HBS-770 Speaker Replacement, Remove Speaker: passo 4, imagem 1 %32
    • Desolder speaker connection from board using a solder iron.
Conclusão
7 outras pessoas executaram este guia.
Faizan Naveed
Membro desde: 04/12/17
3.294 Reputação
Autoria de 8 guias
Equipe
Mobile Device Repair Factory Membro de Mobile Device Repair Factory
Business
1 Membro
Autoria de 16 guias
3 comentários
where do you get the parts
Blaize Lucas - Responder
where to you get the replacement part
Cannibalize another headphone set typically one that is wired and steal the wires from it to replace the worn ones assuming the original speakers aren't blown
michaelwilkins437 -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 7
Duração total: 2,344
