Ir para o conteúdo principal
LG Tone Pro HBS-760 Speaker Replacement
O que você precisa
  1. LG Tone Pro HBS-760 Speaker  Replacement, Locate Hidden Screw: passo 1, imagem 1 %32 LG Tone Pro HBS-760 Speaker  Replacement, Locate Hidden Screw: passo 1, imagem 2 %32 LG Tone Pro HBS-760 Speaker  Replacement, Locate Hidden Screw: passo 1, imagem 3 %32
    • Locate the right and left side speaker where the hidden screw is located and remove the rubber piece covering the screw.
  2. LG Tone Pro HBS-760 Speaker  Replacement, Remove Hidden Screw: passo 2, imagem 1 %32 LG Tone Pro HBS-760 Speaker  Replacement, Remove Hidden Screw: passo 2, imagem 2 %32
    • Using a Philips #00 screwdriver, remove the hidden screws from both sides.
  3. LG Tone Pro HBS-760 Speaker  Replacement, Pry Open Housing: passo 3, imagem 1 %32 LG Tone Pro HBS-760 Speaker  Replacement, Pry Open Housing: passo 3, imagem 2 %32 LG Tone Pro HBS-760 Speaker  Replacement, Pry Open Housing: passo 3, imagem 3 %32
    • Use a guitar pick or any opening tool to pry open the housing for the side you want to replace the speaker.
  4. LG Tone Pro HBS-760 Speaker  Replacement, Desolder Speaker: passo 4, imagem 1 %32 LG Tone Pro HBS-760 Speaker  Replacement, Desolder Speaker: passo 4, imagem 2 %32 LG Tone Pro HBS-760 Speaker  Replacement, Desolder Speaker: passo 4, imagem 3 %32
    • Right side can be de-soldered right away but the left side speaker solder connection to the board is covered by rubber material which needs to be removed first before it can be de-soldered.
  5. LG Tone Pro HBS-760 Speaker  Replacement, Replace Speakers: passo 5, imagem 1 %32
    • Once the speakers have been de-soldered, replace with new ones.
Conclusão
Faizan Naveed
Membro desde: 04/12/17
3.294 Reputação
Autoria de 8 guias
Equipe
Mobile Device Repair Factory Membro de Mobile Device Repair Factory
Business
1 Membro
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 1,496
