Ir para o conteúdo principal
LG Tone Infinim HBS-910 Battery Replacement
O que você precisa
  1. LG Tone Infinim HBS-910 Battery Replacement, Locate right side.: passo 1, imagem 1 %32 LG Tone Infinim HBS-910 Battery Replacement, Locate right side.: passo 1, imagem 2 %32 LG Tone Infinim HBS-910 Battery Replacement, Locate right side.: passo 1, imagem 3 %32
    • Battery is on right side of headset.
    • First remove rubber cover on the right side of the headset to uncover the hidden screw.
    • Remove screw using Philips PH00 screwdriver.
  2. LG Tone Infinim HBS-910 Battery Replacement, Disassemble right side.: passo 2, imagem 1 %32 LG Tone Infinim HBS-910 Battery Replacement, Disassemble right side.: passo 2, imagem 2 %32
    • Use a guitar pick or any opening tool to pry open the right side.
  3. LG Tone Infinim HBS-910 Battery Replacement, Hidden screw.: passo 3, imagem 1 %32 LG Tone Infinim HBS-910 Battery Replacement, Hidden screw.: passo 3, imagem 2 %32 LG Tone Infinim HBS-910 Battery Replacement, Hidden screw.: passo 3, imagem 3 %32
    • Once you have opened the right side up until the speaker end, there will be a hidden screw that needs to be unscrewed before the right side can be completely disassembled.
    • Pry open the speaker back housing with a guitar pick or any opening tool as shown in the picture.
    • Once the speaker back housing is lifted, you will see the screw.
    • Remove the screw and the whole right side will be disassembled.
    Search f9r replacement rechargeable hearing ampliflire batteries
    wayneharnon74graduate - Responder
  4. LG Tone Infinim HBS-910 Battery Replacement, Desolder battery.: passo 4, imagem 1 %32 LG Tone Infinim HBS-910 Battery Replacement, Desolder battery.: passo 4, imagem 2 %32 LG Tone Infinim HBS-910 Battery Replacement, Desolder battery.: passo 4, imagem 3 %32
    • Use a non-metal tool to lift the battery out of place so it will be easy to desolder.
    • Remember the red wire is positive(+) and the black wire is negative(-).
Conclusão
13 outras pessoas executaram este guia.
Faizan Naveed
Membro desde: 04/12/17
3.294 Reputação
Autoria de 8 guias
Equipe
Mobile Device Repair Factory Membro de Mobile Device Repair Factory
Business
1 Membro
Autoria de 16 guias
2 comentários
Battery model and amps
honda kung - Responder
Hello budy!
Tanks for the guide, i was going crazy looking for that hidden screw!
You might be able to help me. Would you know what i must look for a malfunctioning earbud? My right one suddenly died and im hoping the cord isn't broken and its just some loose weld.
Rafael Zerbini - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 27
Duração total: 11,269
