Ferramentas
Peças
Nenhum componente especificado.
Locate the hidden screw as seen in the picture and remove the rubber covering the screw.
Use a guitar pick or any pry opening tool to gently lift the housing until the speaker end. There is a hidden screw that needs to be removed before the housing can be completely removed.
Gently remove the pointy rubber covering using tweezers where the speaker rests as shown in the picture.
Use a Philips #00 screwdriver to remove the hidden screw.
Remove the screw holding the speaker in place using a Philips #00 screwdriver.
Desolder speaker connection using a soldering iron and replace with new speaker.
2 outras pessoas concluíram este guia.
4 comentários
Do you know of a place to buy a replacement speaker?
Excellent instructions and thank you for your time doing this! Can you give a source for the speaker parts other than LG ?
Again thank you
BT Headphone Neckband type with Retractable Earbud (similar contruction ) :: Do you have instructions for repairing loose connection between earbud and wire for model SX-991
