Ir para o conteúdo principal
LG Tone Active HBS-850 Speaker Replacement
O que você precisa
  1. LG Tone Active HBS-850 Speaker Replacement, Locate Hidden Screw: passo 1, imagem 1 %32 LG Tone Active HBS-850 Speaker Replacement, Locate Hidden Screw: passo 1, imagem 2 %32
    • Locate the hidden screw as seen in the picture and remove the rubber covering the screw.
  2. LG Tone Active HBS-850 Speaker Replacement, Remove Hidden Screw: passo 2, imagem 1 %32
    • Remove hidden screw using a Philips #00 screwdriver.
  3. LG Tone Active HBS-850 Speaker Replacement, Pry Open Speaker Housing: passo 3, imagem 1 %32 LG Tone Active HBS-850 Speaker Replacement, Pry Open Speaker Housing: passo 3, imagem 2 %32
    • Use a guitar pick or any pry opening tool to gently lift the housing until the speaker end. There is a hidden screw that needs to be removed before the housing can be completely removed.
  4. LG Tone Active HBS-850 Speaker Replacement, Locate Hidden Speaker Screw: passo 4, imagem 1 %32 LG Tone Active HBS-850 Speaker Replacement, Locate Hidden Speaker Screw: passo 4, imagem 2 %32
    • Gently remove the pointy rubber covering using tweezers where the speaker rests as shown in the picture.
  5. LG Tone Active HBS-850 Speaker Replacement, Remove Hidden Speaker Screw: passo 5, imagem 1 %32 LG Tone Active HBS-850 Speaker Replacement, Remove Hidden Speaker Screw: passo 5, imagem 2 %32
    • Use a Philips #00 screwdriver to remove the hidden screw.
  6. LG Tone Active HBS-850 Speaker Replacement, Remove Speaker Screw: passo 6, imagem 1 %32
    • Remove the screw holding the speaker in place using a Philips #00 screwdriver.
  7. LG Tone Active HBS-850 Speaker Replacement, Desolder Speaker: passo 7, imagem 1 %32 LG Tone Active HBS-850 Speaker Replacement, Desolder Speaker: passo 7, imagem 2 %32
    • Desolder speaker connection using a soldering iron and replace with new speaker.
Conclusão
Faizan Naveed
Membro desde: 04/12/17
3.294 Reputação
Autoria de 8 guias
Equipe
Mobile Device Repair Factory Membro de Mobile Device Repair Factory
Business
1 Membro
Autoria de 16 guias
4 comentários
Do you know of a place to buy a replacement speaker?
James Cimabue - Responder
Excellent instructions and thank you for your time doing this! Can you give a source for the speaker parts other than LG ?
Again thank you
Jim Husselman - Responder
BT Headphone Neckband type with Retractable Earbud (similar contruction ) :: Do you have instructions for repairing loose connection between earbud and wire for model SX-991
Rajesh Narayanan - Responder
Cant find anywhere to buy replacement speakers!
tom - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 11
Duração total: 2,536
