Ir para o conteúdo principal
LG Sunrise Midframe Replacement
O que você precisa
  1. LG Sunrise Midframe Replacement, Back cover: passo 1, imagem 1 %32
    • Flip the phone over so the back side is facing you.
  2. LG Sunrise Midframe Replacement: passo 2, imagem 1 %32
    • Use a prying tool or a flat head screwdriver to pry the back cover from the device.
  3. LG Sunrise Midframe Replacement: passo 3, imagem 1 %32
    • Set back panel aside for later use or to replace.
  4. LG Sunrise Midframe Replacement, Battery: passo 4, imagem 1 %32 LG Sunrise Midframe Replacement, Battery: passo 4, imagem 2 %32
    • Use your finger to pull out battery from the bottom of the device.
  5. Cuidado: os passos de 5 a 6 são provenientes de um guia marcado como em andamento.
    LG Sunrise Midframe Replacement, Lower Back Plastic Piece: passo 5, imagem 1 %32 LG Sunrise Midframe Replacement, Lower Back Plastic Piece: passo 5, imagem 2 %32 LG Sunrise Midframe Replacement, Lower Back Plastic Piece: passo 5, imagem 3 %32
    • You will be first removing the two lower screws. This is allow you to remove the lower plastic piece.
  6. LG Sunrise Midframe Replacement: passo 6, imagem 1 %32
    • Once both of the screws are out you can easily pop off the bottom piece.
  7. LG Sunrise Midframe Replacement, Midframe: passo 7, imagem 1 %32 LG Sunrise Midframe Replacement, Midframe: passo 7, imagem 2 %32
    • Once you have removed all 6 screws. Gently pry all sides of back plastic piece, starting at the bottom. Once you start on the bottom, it will become easier to pry.
  8. LG Sunrise Midframe Replacement: passo 8, imagem 1 %32 LG Sunrise Midframe Replacement: passo 8, imagem 2 %32
    • Once you have pried off the back piece, the mother board should be exposed. Set this piece aside for replacement or reassembly.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 15
Ao todo: 358
