Ir para o conteúdo principal
LG Stylo 3 Plus Speaker Replacement
O que você precisa
  1. LG Stylo 3 Plus Speaker Replacement, Back Cover: passo 1, imagem 1 %32 LG Stylo 3 Plus Speaker Replacement, Back Cover: passo 1, imagem 2 %32 LG Stylo 3 Plus Speaker Replacement, Back Cover: passo 1, imagem 3 %32
    • Power off the phone before beginning disassembly.
    • Place the phone face down.
    • Insert a fingernail or a plastic opening tool into the gap on the side of the phone.
    • Carefully slide your finger or the tool throughout the edge of the phone to ease the back case off.
  2. LG Stylo 3 Plus Speaker Replacement, Battery: passo 2, imagem 1 %32 LG Stylo 3 Plus Speaker Replacement, Battery: passo 2, imagem 2 %32 LG Stylo 3 Plus Speaker Replacement, Battery: passo 2, imagem 3 %32
    • Place the back cover off to the side.
    • Insert the opening tool into the small gap below the battery.
    • Carefully pop the battery out to prevent damage.
  3. LG Stylo 3 Plus Speaker Replacement, Rear Camera: passo 3, imagem 1 %32 LG Stylo 3 Plus Speaker Replacement, Rear Camera: passo 3, imagem 2 %32 LG Stylo 3 Plus Speaker Replacement, Rear Camera: passo 3, imagem 3 %32
    • Remove the twelve 4mm screws using the Phillips #000 screwdriver.
    • Use the plastic opening tool to remove the inner case.
    • Carefully remove the inner case.
  4. LG Stylo 3 Plus Speaker Replacement: passo 4, imagem 1 %32 LG Stylo 3 Plus Speaker Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use your fingernail or the plastic opening tool to flip the flex cable.
    • Use the precision tweezers to carefully grasp and pull out the camera.
  5. LG Stylo 3 Plus Speaker Replacement, Front Camera: passo 5, imagem 1 %32 LG Stylo 3 Plus Speaker Replacement, Front Camera: passo 5, imagem 2 %32
    • Carefully flip open the flex cable box with the plastic opening tool.
    • Using precision tweezers, carefully lift the front camera off the device.
  6. LG Stylo 3 Plus Speaker Replacement, Motherboard: passo 6, imagem 1 %32 LG Stylo 3 Plus Speaker Replacement, Motherboard: passo 6, imagem 2 %32 LG Stylo 3 Plus Speaker Replacement, Motherboard: passo 6, imagem 3 %32
    • Gently flip open the flex cable box using a blue plastic opening tool.
    • Carefully remove the motherboard with your hands or a blue plastic opening tool.
    • Make sure all parts are secure while taking out motherboard.
  7. LG Stylo 3 Plus Speaker Replacement, Top Speaker: passo 7, imagem 1 %32
    • Remove the top speaker.
Conclusão
Dillon Cooper
Membro desde: 09/19/19
175 Reputação
Autoria de 2 guias
Um comentário
Hola gracia por el consejo el altavoz se le rompió a mi cell
Misnelsys Olive - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 1,003
