Ir para o conteúdo principal
LG Stylo 3 Plus Display Assembly Replacement
O que você precisa
  1. LG Stylo 3 Plus Display Assembly Replacement, Back Cover: passo 1, imagem 1 %32 LG Stylo 3 Plus Display Assembly Replacement, Back Cover: passo 1, imagem 2 %32 LG Stylo 3 Plus Display Assembly Replacement, Back Cover: passo 1, imagem 3 %32
    • Power off the phone before beginning disassembly.
    • Place the phone face down.
    • Insert a fingernail or a plastic opening tool into the gap on the side of the phone.
    • Carefully slide your finger or the tool throughout the edge of the phone to ease the back case off.
  2. LG Stylo 3 Plus Display Assembly Replacement, Battery: passo 2, imagem 1 %32 LG Stylo 3 Plus Display Assembly Replacement, Battery: passo 2, imagem 2 %32 LG Stylo 3 Plus Display Assembly Replacement, Battery: passo 2, imagem 3 %32
    • Place the back cover off to the side.
    • Insert the opening tool into the small gap below the battery.
    • Carefully pop the battery out to prevent damage.
  3. LG Stylo 3 Plus Display Assembly Replacement, Rear Camera: passo 3, imagem 1 %32 LG Stylo 3 Plus Display Assembly Replacement, Rear Camera: passo 3, imagem 2 %32 LG Stylo 3 Plus Display Assembly Replacement, Rear Camera: passo 3, imagem 3 %32
    • Remove the twelve 4mm screws using the Phillips #000 screwdriver.
    • Use the plastic opening tool to remove the inner case.
    • Carefully remove the inner case.
  4. LG Stylo 3 Plus Display Assembly Replacement: passo 4, imagem 1 %32 LG Stylo 3 Plus Display Assembly Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use your fingernail or the plastic opening tool to flip the flex cable.
    • Use the precision tweezers to carefully grasp and pull out the camera.
  5. LG Stylo 3 Plus Display Assembly Replacement, Front Camera: passo 5, imagem 1 %32 LG Stylo 3 Plus Display Assembly Replacement, Front Camera: passo 5, imagem 2 %32
    • Carefully flip open the flex cable box with the plastic opening tool.
    • Using precision tweezers, carefully lift the front camera off the device.
  6. LG Stylo 3 Plus Display Assembly Replacement, Motherboard: passo 6, imagem 1 %32 LG Stylo 3 Plus Display Assembly Replacement, Motherboard: passo 6, imagem 2 %32 LG Stylo 3 Plus Display Assembly Replacement, Motherboard: passo 6, imagem 3 %32
    • Gently flip open the flex cable box using a blue plastic opening tool.
    • Carefully remove the motherboard with your hands or a blue plastic opening tool.
    • Make sure all parts are secure while taking out motherboard.
  7. LG Stylo 3 Plus Display Assembly Replacement, Headphone Jack: passo 7, imagem 1 %32 LG Stylo 3 Plus Display Assembly Replacement, Headphone Jack: passo 7, imagem 2 %32
    • Remove the headphone jack.
  8. LG Stylo 3 Plus Display Assembly Replacement, Display Assembly: passo 8, imagem 1 %32
    • The remaining component is your complete display assembly.
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 18
Ao todo: 1,211
