Ir para o conteúdo principal
LG Stylo 3 Plus Battery Replacement
O que você precisa
  1. LG Stylo 3 Plus Battery Replacement, Back Cover: passo 1, imagem 1 %32 LG Stylo 3 Plus Battery Replacement, Back Cover: passo 1, imagem 2 %32 LG Stylo 3 Plus Battery Replacement, Back Cover: passo 1, imagem 3 %32
    • Power off the phone before beginning disassembly.
    • Place the phone face down.
    • Insert a fingernail or a plastic opening tool into the gap on the side of the phone.
    • Carefully slide your finger or the tool throughout the edge of the phone to ease the back case off.
  2. LG Stylo 3 Plus Battery Replacement, Battery: passo 2, imagem 1 %32 LG Stylo 3 Plus Battery Replacement, Battery: passo 2, imagem 2 %32 LG Stylo 3 Plus Battery Replacement, Battery: passo 2, imagem 3 %32
    • Place the back cover off to the side.
    • Insert the opening tool into the small gap below the battery.
    • Carefully pop the battery out to prevent damage.
Conclusão
8 outras pessoas executaram este guia.
Equipe
UMass Dartmouth, Team S2-G6, Peak Fall 2018 Membro de UMass Dartmouth, Team S2-G6, Peak Fall 2018
UMASSD-PEAK-F18S2G6
Membros da 3
Autoria de 15 guias
4 comentários
Thank you for your help. When I took the battery out one of the 4 gold prongs is dirty tried to clean with a toothbrush, do you have any ideas to clean it?
pmorin3887 - Responder
The gold prong in the phone where the battery is
my phone goes from fully charged to 0 in a few minutes, I took the battery out and seen it was a bit bubbled. I have so far bought 3 new batteries for my phone and every time when I turn it on I get invalid battery and it turns off I have left the battery out for a week to reset it but I still get the error when I turn it on… please somebody help
crystalbic - Responder
It is &&^&@@ up you just got to get a new one you know you got to live to die even man-made machines I'm sorry I hope you can find a way to get over it and move on
Deez Blaccnuts -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 4,099
