Introdução
If your LG Stylo 2 Plus sounds muffled or is incapable if making sounds, it might be time to replace the speaker unit. Speaker replacement on this device is a simple task, but you need to remember to gentle; the back is made of plastic and can break.
O que você precisa
To remove the rear case of the phone, insert the spudger into the opening on the back of the case.
With the spudger parallel to the frame of the phone, slide it along the edge, forcing the casing to pop off.
To remove the battery, insert your fingernail or the flat end of the spudger into the dimple at the bottom of the battery and lift upwards.
Firmly grasp the battery and remove from the phone.
Remove the cover from the phone in order to access the speaker.
Using the JIS #000 screwdriver, remove the four 4mm screws around the base of the mid-frame.
Uma outra pessoa concluiu este guia.
