Ir para o conteúdo principal
LG Stylo 2 Plus Front Camera Replacement
O que você precisa
  1. LG Stylo 2 Plus Front Camera Replacement, Rear Case: passo 1, imagem 1 %32 LG Stylo 2 Plus Front Camera Replacement, Rear Case: passo 1, imagem 2 %32 LG Stylo 2 Plus Front Camera Replacement, Rear Case: passo 1, imagem 3 %32
    • To remove the rear case of the phone, insert the spudger into the opening on the back of the case.
    • With the spudger parallel to the frame of the phone, slide it along the edge, forcing the casing to pop off.
  2. LG Stylo 2 Plus Front Camera Replacement, Battery: passo 2, imagem 1 %32 LG Stylo 2 Plus Front Camera Replacement, Battery: passo 2, imagem 2 %32 LG Stylo 2 Plus Front Camera Replacement, Battery: passo 2, imagem 3 %32
    • To remove the battery, insert your fingernail or the flat end of the spudger into the dimple at the bottom of the battery and lift upwards.
    • Firmly grasp the battery and remove from the phone.
  3. LG Stylo 2 Plus Front Camera Replacement, Mid-Frame: passo 3, imagem 1 %32 LG Stylo 2 Plus Front Camera Replacement, Mid-Frame: passo 3, imagem 2 %32
    • Using the JIS #000 screwdriver, remove the eleven 4mm screws around the mid-frame.
  4. LG Stylo 2 Plus Front Camera Replacement: passo 4, imagem 1 %32 LG Stylo 2 Plus Front Camera Replacement: passo 4, imagem 2 %32
    • Insert the metal spudger in the dimple at the base of the cover.
    • Pry upward, removing the mid-frame from the phone.
  5. LG Stylo 2 Plus Front Camera Replacement, Front Camera: passo 5, imagem 1 %32 LG Stylo 2 Plus Front Camera Replacement, Front Camera: passo 5, imagem 2 %32 LG Stylo 2 Plus Front Camera Replacement, Front Camera: passo 5, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using a pair of tweezers, carefully detach the ribbon cable connecting the camera to the motherboard.
    • Still using the tweezers, firmly pull up to remove the camera from the phone.
Conclusão
Joshua Sisson
Membro desde: 05/01/19
73 Reputação
Autoria de 1 guia
Equipe
UW Tacoma, Team S1-G3, Cardinal Spring 2019 Membro de UW Tacoma, Team S1-G3, Cardinal Spring 2019
UWT-CARDINAL-S19S1G3
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 273
