Ir para o conteúdo principal
LG Stylo 2 Motherboard Replacement
O que você precisa
  1. LG Stylo 2 Motherboard  Replacement, Battery: passo 1, imagem 1 %32 LG Stylo 2 Motherboard  Replacement, Battery: passo 1, imagem 2 %32 LG Stylo 2 Motherboard  Replacement, Battery: passo 1, imagem 3 %32
    • First you need to remove the back case of the phone.
    • Place the phone face down.
    • Using the plastic opening tool, insert into the initial gap shown.
    • Slowly guide the tool around the case until the case comes off with ease.
  2. LG Stylo 2 Motherboard  Replacement: passo 2, imagem 1 %32 LG Stylo 2 Motherboard  Replacement: passo 2, imagem 2 %32 LG Stylo 2 Motherboard  Replacement: passo 2, imagem 3 %32
    • Place the back case to the side.
    • Use your finger or the opening tool to remove battery.
    • Remove the battery carefully to not damage the phone or the battery.
  3. LG Stylo 2 Motherboard  Replacement, Rear Camera: passo 3, imagem 1 %32 LG Stylo 2 Motherboard  Replacement, Rear Camera: passo 3, imagem 2 %32 LG Stylo 2 Motherboard  Replacement, Rear Camera: passo 3, imagem 3 %32
    • Remove the eleven 4mm Phillips #00 screws.
    • Place screws in safe location.
    • Use Plastic opener tool to remove inner case.
    • Gently remove inner case.
  4. LG Stylo 2 Motherboard  Replacement: passo 4, imagem 1 %32 LG Stylo 2 Motherboard  Replacement: passo 4, imagem 2 %32 LG Stylo 2 Motherboard  Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use your finger or the opener to flip the flex cable shown in red box.
    • Use the precision tweezers to remove camera carefully.
  5. LG Stylo 2 Motherboard  Replacement, Motherboard: passo 5, imagem 1 %32 LG Stylo 2 Motherboard  Replacement, Motherboard: passo 5, imagem 2 %32 LG Stylo 2 Motherboard  Replacement, Motherboard: passo 5, imagem 3 %32
    • Gently flip the cables(shown in red boxes) using the opener tool.
    • Gently remove the motherboard itself.
    • Place motherboard on a soft surface to not damage it.
Conclusão
Devon Barber
Membro desde: 02/13/18
994 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S11-G1, Cheng Spring 2018 Membro de USF Tampa, Team S11-G1, Cheng Spring 2018
USFT-CHENG-S18S11G1
Membros da 4
Autoria de 10 guias
Um comentário
Charging retain 2.1
Kashif Kashi - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 18
Duração total: 2,265
