Ir para o conteúdo principal
LG Stylo 2 Display Replacement
O que você precisa
  1. LG Stylo 2 Display Replacement, Battery: passo 1, imagem 1 %32 LG Stylo 2 Display Replacement, Battery: passo 1, imagem 2 %32 LG Stylo 2 Display Replacement, Battery: passo 1, imagem 3 %32
    • First you need to remove the back case of the phone.
    • Place the phone face down.
    • Using the plastic opening tool, insert into the initial gap shown.
    • Slowly guide the tool around the case until the case comes off with ease.
    Pergunte ao FixBot
    Comentar
  2. LG Stylo 2 Display Replacement: passo 2, imagem 1 %32 LG Stylo 2 Display Replacement: passo 2, imagem 2 %32 LG Stylo 2 Display Replacement: passo 2, imagem 3 %32
    • Place the back case to the side.
    • Use your finger or the opening tool to remove battery.
    • Remove the battery carefully to not damage the phone or the battery.
    Pergunte ao FixBot
    Comentar
  3. LG Stylo 2 Display Replacement, Rear Camera: passo 3, imagem 1 %32 LG Stylo 2 Display Replacement, Rear Camera: passo 3, imagem 2 %32 LG Stylo 2 Display Replacement, Rear Camera: passo 3, imagem 3 %32
    • Remove the eleven 4mm Phillips #00 screws.
    • Place screws in safe location.
    • Use Plastic opener tool to remove inner case.
    • Gently remove inner case.
    Pergunte ao FixBot
    Comentar
  4. LG Stylo 2 Display Replacement: passo 4, imagem 1 %32 LG Stylo 2 Display Replacement: passo 4, imagem 2 %32 LG Stylo 2 Display Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use your finger or the opener to flip the flex cable shown in red box.
    • Use the precision tweezers to remove camera carefully.
    Pergunte ao FixBot
    Comentar
  5. LG Stylo 2 Display Replacement, Motherboard: passo 5, imagem 1 %32 LG Stylo 2 Display Replacement, Motherboard: passo 5, imagem 2 %32 LG Stylo 2 Display Replacement, Motherboard: passo 5, imagem 3 %32
    • Gently flip the cables(shown in red boxes) using the opener tool.
    • Gently remove the motherboard itself.
    • Place motherboard on a soft surface to not damage it.
    Pergunte ao FixBot
    Comentar
  6. LG Stylo 2 Display Replacement, Display: passo 6, imagem 1 %32 LG Stylo 2 Display Replacement, Display: passo 6, imagem 2 %32 LG Stylo 2 Display Replacement, Display: passo 6, imagem 3 %32
    • Carefully remove the Vibrator.
    • Carefully remove the sensor.
    • Prepare to remove film.
    Pergunte ao FixBot
    Comentar
  7. LG Stylo 2 Display Replacement: passo 7, imagem 1 %32 LG Stylo 2 Display Replacement: passo 7, imagem 2 %32 LG Stylo 2 Display Replacement: passo 7, imagem 3 %32
    • Use the tweezers to peel the film off carefully.
    • Use the tweezers to remove the headphone jack gently.
    • Place all three devices in a safe, known, location.
    Pergunte ao FixBot
    Comentar
Conclusão
15 outras pessoas executaram este guia.
Devon Barber
Membro desde: 02/13/18
994 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S11-G1, Cheng Spring 2018 Membro de USF Tampa, Team S11-G1, Cheng Spring 2018
USFT-CHENG-S18S11G1
4 Membros
Autoria de 15 guias
2Comentários do guia
Hello guys
I just replaced the screen for my LG Stylus 2 plus. I got the display off https://www.injuredgadgets.com/lg-stylus...
But after replacing the screen and turning it on only the back light is functioning. I tried reusing the old display and it worked just fine. Is there any suggestions to why this one is not working or is my new screen just a bust ?
Several Genie - Responder Compartilhar
I've got the same problem please help this phone has all my late sons pictures and my daughter's it's a LG Stylo 2
Cody Pinson - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 44
Ao todo: 6,542
